49TAFAR76_8n
New User
:roll:
Were really puzzeled why our old tractor wont start. It was fine up the time I parked it for the winter, after mowing fields.
1. It does not get spark to turn over.
a. I checked battery- It is fine, only few months old, cables good.
2.checked all connections, cleaning all.
3. Checked Starter: Its fine
4. Replaced solinoide: Re-attached exactly same as before
5. Replaced Starter switch: New
6. Replaced Starter button: New
7. Replaced Terminal Block: New
8. Replaced Spk plugs: New/plug wires good-2 yrs old
9. Checked Distributor OK/points ok
10. checked ground point: Cleaned connections.
All this and it still will not even turn over! :?
P.S. Engine is not siezed, will turn over by cross wiring the solinoide.
Any Ideas?
Getting desparate, field grass is now up to my sholders.
If re-wiring the whole shubang is in order, direction on corect gauges to use would be helpful. Cant tell exactly with the old
wires still in place.
This post was edited by 49TAFAR76_8n on 06/08/2022 at 02:08 pm.
Any Ideas?
