Tire issue and questions 12-28 4 ply
I've had this tractor for around 7 years now.
Mostly plows snow and cuts grass. Pulls logs
once in awhile Gets about 50 hours a year
usage.
The rear loaded rear tires (calcium) have
looked like they need air since I bought it
but I always hesitate. When I bought it I
noticed the bulge/patch on the sidewall. I
told the seller it looked like trouble. He
said it was vulcanized 15-20 years ago and
would probably hold another 20. Valve stems
and surrounding area are rough but doesn't
seem to be leaking. Should I try to add air
or leave well enough alone. Thanks! Paul
And if you do try to add air, make sure you buy a couple new valve cores first. I added air to my old IH this spring, first time in the 10 years I have owned it. Both valve stems leaded immediately and I had to replace them. Was able to find new ones at NAPA, but only a couple was all they had.
Tim
Yesterday I had to patch the inner tube on my bicycle.
I was thinking I wish all tires were as easy to repair as a bicycle tire..
I bet you might wish it was as easy as a bicycle tire if you have to replace this tire..
I'm too old to even think of doing this job. I would use my loader, put it in my truck, and haul it to a tractor tire shop.
My tire shop can also repair tractor rims. One trip and done..
Look to see if the stem screws into the tube or onto the tube. The short piece the core goes into. If it screw into it then with the stem up and no weight on the wheel unscrew the stem and put a new one in. This is the fastest least leak change program. You can then change the core with no issue of Chloride spraying around on things. I then save the old stems for other jobs in tubes for use. Then after you are done with the stem you can ad air to suit then.
Thanks very much to all of you for your feedback. . There has been no real change in the tires since I've owned the tractor. Now that I know there's a fair chance of creating a problem it sounds like the smartest move is to just let them alone. If I really need to add air, I've got a good way to go about replacing the valve stems. Of I've missed something, let me know. Thanks again Paul
Traditional farmer, I'm sure you are correct! I'm keeping my eyes open for a good deal and need to find a place that can do it. No longer any places that do ag tires near me. Thanks Paul
