Josh in Pa
I have had a 1755 for a short while, and put maybe 10-20 hours on it. The other day it started leaking hydraulic oil badly, between the manifold and 1st control valve on the right of the seat under the side console. It sprays oil out when first started, but if it runs a few minutes, the leak stops. This tractor also has the typical burps and whines that they do when the pump sucks some air. It looks like there are 7 o rings between each section (21 total). Is this just an old o ring that blew out, or is something getting over pressurized? Thanks,
Josh
Josh
