Case IH 2250 mount for a 560 Farmall
Farmer DanG
New User
My son bought a Farmall 560 with a 2000 IH loader on it but we want to mount my 2250 loader on it because of the mount o matic. I had it on a 656 but sold the tractor. I have the mounts and everything for it. My question is how do I make it work? Can I use the same mounts? Does anyone have pictures of one mounted so I can see what to expect or how to do it? My 2250 loader is like brand new and is definitely the better loader. Thanks in advance for any help.
Dan
It should bolt on exactly the same as it was on the 656. All the dimensions and bolt holes up front are exactly the same. The only difference is at the bell housing, where the 656 is narrower by an inch on each side.
When I removed the mount that must be the difference with the spacer plates I removed then. I take it I can put it on without those spacers than correct?
