Warning flag mount
JimS
I am looking for warning flag mounts that can flip in
and out.
I have a narrow trailer Id like to mount them on to
improve visibility when backing.
If I understand you, you are wanting something hanging out to each side that you will be able to see in your mirrors so that you will know where your tailer is when you are backing. Many guys use a flexible two foot long fiberglass rod that is made to mount in the top surface of a bumper of a truck. They are often yellow, but I have seen plenty that are orange. They are permanently mounted on a lot of trailed equipment such as a chipper. They don't need to flip in because they are not over width.
Since I already have some, I would use a Neodymium Magnet as the base of flag mast.
90lbs pull and they do hold very well, takes enough effort to remove. I have to slide it off an edge or use a bolt in the hole to lever it off.
A wide array of styles and strengths on azon.
