Wanted Allis chalmers d19 engine
a gas engine would be perfect , Im located in northern Vt , was hoping to find a complete engine out of a d19 to install in my cockshutt 40
Im going to mainly use the tractor for pulling so maybe someone could help point me in the best direction between the d19 engine and the combine
Combine 262 is the same.You'll have to put the rear adapter plate and the front plates from the 40 on the engine meaning you;ll need to pull the camshafts,Be alert on the Camshaft as the AC and the Cockshutt cam marks are usually 180 out.
(quoted from post at 19:12:00 05/18/22) Im going to mainly use the tractor for pulling so maybe someone could help point me in the best direction between the d19 engine and the combine
Are you gong to be pulling mainly in the Northeast Kingdom or over towards New York?
Id heard that the water pumps some times need to be changed on the combine style engine to fit , any truth to this ?
My email is vancesteve@ hotmail.com could you email me your guys names and phone numbers so I can call you on the engines to discuss price and conditions thank you
(quoted from post at 18:57:03 05/19/22) Id heard that the water pumps some times need to be changed on the combine style engine to fit , any truth to this ?
You want to remove the space from that address.
