New-to-me cider press
rockyridgefarm
Picked this up yesterday. Needs some boards replaced. I hope to use it to press cider this fall.
It has an elevator that is not in the pic. The elevator feeds apples (or pears) to the macerator on the top right in the second pic. You make the stack with alternating canvas bags and wooden grates. Once you make the stack, you use a cable and pulley to drag the stack under the press. Then you push a lever over to engage a bevel gear to drive the screw down to press the mash. While you wait for it to drain. You make the next stack. It is pry over 100 years old.
Way too old for any of that, just only automatic is your brain. Years ago one in my area and he ran it hooked to belt on his Moline U tractor and just idled the tractor.
