New toy followed me home and my latest submission to the
Adrian Billheimer
New to me IH 484, brought it home today, it purrs nicely, and I dare anyone to find something wrong with my
tie downs. :>)
They were a nice little tractor for many jobs. Use HYTran hydraulic oil. I dont know what additives CaseIH HYTRAN has in it that other hydraulic oils dont have. But my brother uses cheap Wally World hydraulic oil and he never has parking brakes or regular wheel brakes that work well on any of his 4 584 CaseIH tractors. And my friend always used HYTran and never had the oil eat his brakes.
According to DOT the binder handles need to be fastened. Wrapping the chain does not count even though that is what I do as well. LOL Looks like a nice little tractor. Tom
Unfortunately, only the brackets, if anyone knows of a Woods/Dual 210 loader within a days' drive of NE Pa. for sale, please let me know.
I see the chain is inside of the rail so a side swipe won't unfasten the chain. Good thinking! Nice tractor!
yup thwe binder handles and as for the hytran deal we used that on our 574 and it spent more time being worked on for brakes and power steering issues than used at first. It has not had Hytran in it in the last 40 years with no brake or steering problems nor brakes ate up. It is now in the last year just started to have a brake problem internally. I need to pull the left axle to see what the problem is. With a loader on it it is difficult to get it down long enough to look at it though.
(quoted from post at 17:47:02 05/17/22) According to DOT the binder handles need to be fastened. Wrapping the chain does not count even though that is what I do as well. LOL Looks like a nice little tractor. Tom
Tom, Help me out here.I can't find where it tells that the handle needs to be secured. All I can find is that it cannot come loose. If the control lever of a ratchet type binder is in the "tighten" position there is no way that the handle can loosen the chain right?
Cargo Securement Rules
Background
On September 27, 2002, the Federal Motor Carrier Safety Administration (FMCSA) published new cargo securement rules. Motor carriers operating in interstate commerce must comply with the new requirements beginning January 1, 2004. The new rules are based on the North American Cargo Securement Standard Model Regulations, reflecting the results of a multi-year research program to evaluate U.S. and Canadian cargo securement regulations; the motor carrier industry's best practices; and recommendations presented during a series of public meetings involving U.S. and Canadian industry experts, Federal, State and Provincial enforcement officials, and other interested parties. The new rules require motor carriers to change the way they use cargo securement devices to prevent articles from shifting on or within, or falling from commercial motor vehicles. The changes may require motor carriers to increase the number of tiedowns used to secure certain types of cargo. However, the rule generally does not prohibit the use of tiedowns or cargo securement devices currently in use. Therefore, motor carriers are not required to purchase new cargo securement equipment or vehicles to comply with the rule. The intent of the new requirements is to reduce the number of accidents caused by cargo shifting on or within, or falling from, commercial motor vehicles operating in interstate commerce, and to harmonize to the greatest extent practicable U.S., Canadian, and Mexican cargo securement regulations.
Applicability of the New Rules
The new cargo securement rules apply to the same types of vehicles and cargo as the old rules, covering all cargo-carrying commercial motor vehicles (as defined in 49 CFR 390.5) operated in interstate commerce. This includes all types of articles of cargo, except commodities in bulk that lack structure or fixed shape (e.g., liquids, gases, grain, liquid concrete, sand, gravel, aggregates) and are transported in a tank, hopper, box or similar device that forms part of the structure of a commercial motor vehicle.
Performance Criteria
FMCSA has adopted new performance requirements concerning deceleration in the forward direction, and acceleration in the rearward and lateral directions, that cargo securement systems must withstand. Deceleration is the rate at which the speed of the vehicle decreases when the brakes are applied, and acceleration is the rate at which the speed of the vehicle increases in the lateral direction or sideways (while the vehicle is turning), or in the rearward direction (when the vehicle is being driven in reverse and makes contact with a loading dock). Acceleration and deceleration values are commonly reported as a proportion of the acceleration due to gravity (g). This acceleration is about 9.8 meters/second/second (32.2 feet/second/second), which means that the velocity of an object dropped from a high elevation increases by approximately 9.8 meters/second (32.2 feet/second) each second it falls. FMCSA requires that cargo securement systems be capable of withstanding the forces associated with following three deceleration/accelerations, applied separately:
0.8 g deceleration in the forward direction;
0.5 g acceleration in the rearward direction; and
0.5 g acceleration in a lateral direction.
These values were chosen based on researchers' analysis of studies concerning commercial motor vehicle performance. The analysis indicated that the highest deceleration likely for an empty or lightly loaded vehicle with an antilock brake system, all brakes properly adjusted, and warmed to provide optimal braking performance, is in the range of 0.8-0.85 g. However, a typical loaded vehicle would not be expected to achieve a deceleration greater than 0.6 g on a dry road. The typical lateral acceleration while driving in a curve or on a ramp at the posted advisory speed is in the range 0.05-0.17 g. Loaded vehicles with a high center of gravity roll over at a lateral acceleration above 0.35 g. Lightly loaded vehicles, or heavily loaded vehicles with a lower center of gravity, may withstand lateral acceleration forces greater than 0.5 g.
Generally, motor carriers are not required to conduct testing of cargo securement systems to determine compliance with the performance requirements. The new rules explicitly state that cargo immobilized or secured in accordance with the general securement rules, or the commodity-specific rules, are considered to meet the performance criteria.
Requirements for Securement Devices
The new rules require that all devices and systems used to secure cargo to or within a vehicle must be capable of meeting the performance criteria. All vehicle structures, systems, parts and components used to secure cargo must be in proper working order when used to perform that function with no damaged or weakened components that could adversely affect their performance. The cargo securement rules incorporate by reference manufacturing standards for certain types of tiedowns including steel strapping, chain, synthetic webbing, wire rope, and cordage. FMCSA has updated the rules to reference the November 15, 1999, version of the National Association of Chain Manufacturers (NACM) Welded Steel Chain Specifications. The agency notes that some of the working load limit values in the 1999 version differ slightly from the previous edition of this publication. Also, the 1999 version includes working load limits for a new grade of alloy chain, grade 100. The agency also changed its reference for synthetic webbing from the 1991 edition to the 1998 edition of the Web Sling and Tiedown Association's publication. Generally, the working load limits are the same as those in the 1991 publication. Changes in the references do not necessarily mean the older securement devices need to be replaced. Motor carriers are not required to replace tiedown devices purchased prior to January 1, 2004. If the tiedowns satisfied the old rules, the devices should also satisfy the new rules.
Proper Use of Tiedowns
The new regulations require each tiedown to be attached and secured in a manner that prevents it from becoming loose, unfastening, opening or releasing while the vehicle is in transit. All tiedowns and other components of a cargo securement system used to secure loads on a trailer equipped with rub rails must be located inboard of the rub rails whenever practicable. Also, edge protection must be used whenever a tiedown would be subject to abrasion or cutting at the point where it touches an article of cargo. The edge protection must resist abrasion, cutting and crushing.
Use of Unmarked Tiedowns
The new rules do not prohibit the use of unmarked tiedown devices. Although many of the participants in the public meetings and numerous commenters to the rulemaking proposal argued the rules should include such a prohibition, FMCSA believes it is inappropriate to prohibit unmarked tiedowns at this time. However, in view of the potential safety hazards of motor carriers misidentifying unmarked tiedowns, there is a provision that unmarked welded steel chain be considered to have a working load limit equal to that of grade 30 proof coil, and other types of unmarked tiedowns be considered to have a working load limit equal to the lowest rating for that type in the table of working load limits.
Unrated and Unmarked Anchor Points
FMCSAs cargo securement rules do not require rating and marking of anchor points. While the agency encourages manufacturers to rate and mark anchor points, the new rules do not include a requirement for ratings and markings.
Front End Structures on CMVs
FMCSA revised its rules concerning front-end structures or headerboards by changing the applicability of the requirements to cover CMVs transporting cargo that is in contact with the front-end structure of the vehicle. By contrast, the old rules required certain vehicles to be equipped with front-end structures regardless of whether the devices were used as part of a cargo securement system.
Summary of the new cargo rules
The new cargo securement rules include general securement rules applicable to all types of articles of cargo, with certain exceptions, and commodity-specific rules covering commodities that are considered the most difficult to determine the most appropriate means of securement. Requirements concerning securement, working load limits, blocking and bracing are applicable to all commodities being transported. The commodity-specific requirements take precedence over the general rules when additional requirements are given for a commodity listed in those sections. This means all cargo securement systems must meet the general requirements, except to the extent a commodity-specific rule imposes additional requirements that prescribe in more detail the securement method to be used.
General Rule
Cargo must be firmly immobilized or secured on or within a vehicle by structures of adequate strength, dunnage (loose materials used to support and protect cargo) or dunnage bags (inflatable bags intended to fill space between articles of cargo or between cargo and the wall of the vehicle), shoring bars, tiedowns or a combination of these.
Cargo Placement and Restraint
Articles of cargo that are likely to roll must be restrained by chocks, wedges, a cradle or other equivalent means to prevent rolling. The means of preventing rolling must not be capable of becoming unintentionally unfastened or loose while the vehicle is in transit. Articles of cargo placed beside each other and secured by transverse tiedowns must be:
Placed in direct contact with each other, or
Prevented from shifting towards each other while in transit.
Minimum Working Load Limit for Cargo Securement Devices and Systems
The aggregate working load limit of any securement system used to secure an article or group of articles against movement must be at least one-half the weight of the article or group of articles. The aggregate working load limit is the sum of: One-half the working load limit of each tiedown that goes from an anchor point on the vehicle to an attachment point on an article of cargo; and The working load limit for each tiedown that goes from an anchor point on the vehicle, through, over or around the cargo and then attaches to another anchor point on the vehicle.
Minimum Number of Tiedowns
The cargo securement system used to restrain articles against movement must meet requirements concerning the minimum number of tiedowns. This requirement is in addition to complying with rules concerning the minimum working load limit. When an article of cargo is not blocked or positioned to prevent movement in the forward direction, the number of tiedowns needed depends on the length and weight of the articles. There must be - one tiedown for articles 5 ft or less in length, and 1,100 lbs or less in weight; two tiedowns if the article is -
5 ft or less in length and more than 1,100 lbs in weight; or
greater than 5 ft but less than 10 ft, regardless of weight.
In the following example, one tiedown is required because the article of cargo is 5 ft in length and does not exceed 1,100 lbs. If the article of cargo were greater than 5 ft in length but less than 10 ft, two tiedowns would be needed regardless of the weight. When an article of cargo is not blocked or positioned to prevent movement in the forward direction, and the item is longer than 10 ft in length, then it must be secured by two tiedowns for the first 10 ft of length, and one additional tiedown for every 10 ft of length, or fraction thereof, beyond the first 10 ft. An example of this is provided below. If an article is blocked, braced or immobilized to prevent movement in the forward direction by a headerboard, bulkhead, other articles that are adequately secured, or other appropriate means, it must be secured by at least one tiedown for every 10 ft of article length, or fraction thereof.
Special Rule for Special Purpose Vehicles
Generally, the basic rules concerning the minimum number of tiedowns do not apply to a vehicle transporting one or more articles of cargo such as, but not limited to, machinery or fabricated structural items (e.g., steel or concrete beams, crane booms, girders, and trusses, etc.) which, because of their design, size, shape or weight, must be fastened by special methods. However, any article of cargo carried on that vehicle must be secured adequately to the vehicle by devices that are capable of meeting the performance requirements and the working load limit requirements.
Commodity-Specific Securement Requirements
FMCSA has adopted detailed requirements for the securement of the following commodities: logs; dressed lumber; metal coils; paper rolls; concrete pipe; intermodal containers; automobiles, light trucks and vans; heavy vehicles, equipment and machinery; flattened or crushed vehicles; roll-on/roll-off containers; and large boulders. During public meetings concerning the development of the model regulations, participants said that these commodities cause the most disagreement between industry and enforcement agencies as to what is required for proper securement.
393.116 - Logs
The rules for the transportation of logs are applicable to the transportation of almost all logs with the following exceptions:
Logs that are unitized by banding or other comparable means may be transported in accordance with the general cargo securement rules.
Loads that consist of no more than four processed logs may be transported in accordance with the general cargo securement rules.
Firewood, stumps, log debris and other such short logs must be transported in a vehicle or container enclosed on both sides, front, and rear and of adequate strength to contain them. Longer logs may also be transported in an enclosed vehicle or container.
393.118 - Dressed Lumber and Similar Building Products
The rules in this section apply to the transportation of bundles of dressed lumber, packaged lumber, building products such as plywood, gypsum board or other materials of similar shape. Lumber or building products that are not bundled or packaged must be treated as loose items and transported in accordance with the general cargo securement rules. For the purpose of this section, the term " bundle " refers to packages of lumber, building materials or similar products which are unitized for securement as a single article of cargo.
393.120 - Metal Coils
The rules in this section apply to the transportation of one or more metal coils which, individually or grouped together, weigh 2,268 kg (5,000 lbs) or more. Shipments of metal coils that weigh less than 2,268 kg (5,000 lbs) may be secured in accordance with the general cargo securement rules.
393.122 - Paper Rolls
The rules for securing paper rolls are applicable to shipments of paper rolls which, individually or together, weigh 2,268 kg (5,000 lbs) or more. Shipments of paper rolls that weigh less than 2,268 kg (5,000 lbs), and paper rolls that are unitized on a pallet, may either be secured in accordance with the rules in this section or the general cargo securement rules.
393.124 - Concrete Pipe
The rules in this section apply to the transportation of concrete pipe on flatbed trailers and vehicles and lowboy trailers. Concrete pipe that is bundled tightly together into a single rigid article with no tendency to roll, and concrete pipe loaded in a sided vehicle or container must be secured in accordance with the general rules.
393.126 - Intermodal Containers
The requirements for intermodal containers cover the transportation of these containers on container chassis and other types of vehicles. Intermodal containers are freight containers designed and constructed to permit them to be used interchangeably in two or more modes of transportation. Cargo contained within intermodal containers must be secured in accordance with the general cargo securement rules or, if applicable, the commodity-specific rules.
393.128 - Automobiles, Light Trucks and Vans
This portion of the new standards applies to the transportation of automobiles, light trucks, and vans which individually weight 4,536 kg (10,000 lbs) or less. Vehicles which individually are heavier than 4,536 kg (10,000 lbs) must be secured in the same manner as heavy vehicles, equipment and machinery (see the rules under /393.126).
393.130 - Heavy Vehicles, Equipment and Machinery
These requirements are applicable to the transportation of heavy vehicles, equipment and machinery which operate on wheels or tracks, such as front end loaders, bulldozers, tractors and power shovels and which individually weigh 4,536 kg (10,000 lbs) or more. Vehicles, equipment and machinery which is lighter than 4,536 kg (10,000 lbs) may be secured in accordance with these rules, the rules for automobiles, light trucks and vans, or the general freight requirements.
393.132 - Flattened or Crushed Vehicles
The transportation of vehicles such as automobiles, light trucks and vans that have been flattened or crushed is covered by these requirements. The transportation of automobiles that are flattened or crushed in a crash or accident, as opposed to being intentionally flattened or crushed in preparation for transportation to recycling facilities, is not subject to these requirements. However, vehicles damaged in a crash or accident are subject to the general cargo securement requirements.
393.134 - Roll-on/Roll-Off or Hook-lift Containers
These rules apply to the transportation of roll-on/roll-off or hook lift containers. A hook-lift container is defined in 49 CFR 393.5 as a specialized container, primarily used to contain and transport materials in the waste, recycling, construction/demolition and scrap industries, which is used in conjunction with specialized vehicles in which the container is loaded and unloaded onto a tilt frame body by an articulating hook-arm. Section 393.134 is not, however, applicable to the operation of hoist-type equipment (or hoist equipment) as described in American National Standards Institute (ANSI) publication ANSI 2245.1. Hoist-type equipment should be considered separate and distinct from roll-on/roll-off equipment and, therefore, not subject to 393.134. Containers transported on hoist-type equipment must be secured in accordance with the general securement rules.
393.136 - Large Boulders
The rules in this section are applicable to the transportation of any large piece of natural, irregularly shaped rock weighing in excess of 5,000 kg (11,000 lbs) or with a volume in excess of 2 cubic-meters on an open vehicle, or in a vehicle whose sides are not designed and rated to contain such cargo. Pieces of rock weighing more than 100 kg (220 lbs), but less than 5,000 kg (11,000 lbs) must be secured, either in accordance with this section, or in accordance with the general cargo securement rules, including: (1) rock contained within a vehicle which is designed to carry such cargo; or (2) secured individually by tiedowns, provided each piece can be stabilized and adequately secured. Rock which has been formed or cut to a shape and which provides a stable base for securement must also be secured, either in accordance with the provisions of this section or in accordance with the general securement rules.
Vehicle and Roadside Operations Division (MC-PSV)
1200 New Jersey Avenue SE
Washington, DC 20590
www.fmcsa.dot.gov
Publication No.: MC-P/PSV-04-001
Last updated: Monday, March 3, 2014
I see nothing wrong with your securing load. Good job,
Is your trailer a suritrack?
Two deck boards on my suritack needed replaced. They only lasted 11 years.
I bought CCA lumber from Menards to repair mine..
Nice tractor..enjoy it..
How does one secure the handles, if they have no securing function built in?
Wrapping a chain doesnt count, so what would?
Paul
The law also says that you need four individual chains at each of four corners if the idem weighs 8000 pounds or over. Otherwise two a significant.
Good job securing your tractor. My grandfather insisted that all over center type binders be opened and closed with a four foot pipe. All loads were checked before entering an actual road and rechecked before entering a class A road. Any binder showing signs of damage was discarded.
To Tomturkey's post -
In Iowa they require it. My buddy years ago was hauling his skid steer and was pulled over by the DOT and the only thing they could write him up for was not binding the binders to the chain with some wire. Reason behind it a DOT told me is if the chain unwinds itself it could possibly damage a vehicle in the lane next to your trailer. I'm in Iowa and I personally use a piece of wire to connect my binders to my chains. Whether truly needed or not I'll pass on a ticket.
This post was edited by Meangreen on 05/18/2022 at 10:56 am.
