Case CK 930
If I recall right, there is a breather on the left rear that is the dip stick and filler.
Bump up underneath it and it should pop right up.
6 speed 930 or 8 spd? 8 speed has a breather with a dipstick to the left of the pto shaft. 6 speed has the filler under a square plate on the floor board...and check plug is to the right of the pto by the axle housing.
Don't forget that the hydraulic reservoir is not part of the rear end on the 6 speed 930 CK. 6 speed hydraulic reservoir level is checked and filled on the left side of PTO. Little dipstick attached to cap.
