boatmanjj24
New User
I own a 2500b gas with a loader when the loader has a load on it the power steering is weak and there is a lot of chatter and noise from Mcv valve side. When there's no load on the tractor the steering functions but there is an awful lot of noise hydraulic related. The biggest issue is lack of power under load to the steering I am getting ready to investigate this but a few good directions on which way to head to troubleshoot what the problem might be would be helpful. I have changed fluids and filters already and there is no air lock issue. PTO works and the 3-point arms work. Also there is an issue with the brakes I have bled them but no luck. They worked minimally in the past but now we have no breaks whatsoever when they were working minimally you had to pump them up a few times to get them to stop at all. What way would I have to go to also troubleshoot that problem along with the steering problem?
