flying belgian
Couple months ago I got this pu with 275,000 miles I asked you what could be wrong if it won't idle when engine cold. You said it was probably some little valve on back of carb needs cleaning or replace. I took it off, cleaned it up, tapped on it with a wooden hammer. And put it back on. Bingo. Thing idles and runs real nice when engine cold or hot. Now the next thing is it cranks a long time when you start it. Always did. It cranks real fast and always starts but it seams like it should start faster without all that cranking. Could that be that same valve on carb? What did you call that valve? And should I replace it for my starting problem?
