(quoted from post at 10:00:45 05/09/22) My chain saw calls for 50-1 ratio(2.6 ounces oil to 1 gallon gas). Is 2.6 fluid
ounces equal to if you weight 2.6 ounces on a weight scale?
(quoted from post at 19:16:38 05/09/22) These are around $4-$5. It is a measuring cup just for this.
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto125390.jpg>
(quoted from post at 19:09:13 05/09/22) Showcrop, he said his saw calls for 50-1, and your telling him to mix it about 25-1, why? That much oil
will cause way more problems than it solves, and a lot of smoke!
Imperial system is pretty simple to me. 32 ounces of gas to 1 ounce of oil and there you go. Multiply by whatever amount you need. Of course I am that guy that grew up with the imperial system and was forced to learn the metric measures in later years.(quoted from post at 10:49:41 05/09/22) Darned Imperial measurement system anyways. Gallons are bad enough, add ounces into the mix .
(quoted from post at 19:59:02 05/10/22) To answer your question, No. A fluid ounce is a measure of capacity (size) not a measure of weight.
(quoted from post at 22:17:43 05/10/22)Imperial system is pretty simple to me. 32 ounces of gas to 1 ounce of oil and there you go. Multiply by whatever amount you need. Of course I am that guy that grew up with the imperial system and was forced to learn the metric measures in later years.(quoted from post at 10:49:41 05/09/22) Darned Imperial measurement system anyways. Gallons are bad enough, add ounces into the mix .
