old
- Location
- Camdenton Missouri
So got a call to look at a 3 point till that lost drive power. It has a hex drive that goes into a gear that in turn drives 2 other gears and drives the tines. The hex drive that goes in to the upper gear looks ot be twisted and stripped. It appear to not have even been inside the gear more the maybe 1/2 inch. It also appears that one could cut off the bad part and then slide the shaft back in.
So have any of you ever worked on one of these and does that sound about right??
Thanks
Thanks
