Ford naa rocker Shaft oil tubes
Ac145
Have what does appears to be 3/16 OD tubing coming up through the center of the head. Then bent around going around and turning down into the rocker shaft port above number four cylinder. Then on the rocker shaft at the end which is about above number one cylinder there is an opening. Now that I have this thing running I can see that there is oil being pumped out of that hole at the end of the shaft which is about like I said above number one cylinder. So is that how the shaft is fed with the oil just from that one tube and then flowing through it and being pumped out that other port.
OK thanks for that info and will look for that other hole. do you know if that tubing just fits down into the rocker arm and just short of looking do you Gotta make your own or is it available to buy.
I am not seeing a front drain hole. Or does that tube from the front hole on the rocker shaft just Bend around and would end up going alongside one of the rocker arm push rod holes.
