Tryinmybest
New User
My rail rims ( 5 rails ) are severely rusted and I don't need that type. I already have new tubes and good 14.9 x 28 tires. I have a 1975 Ford 4000 3cyl gas. I don't no which 3L engine I have. It's not a row tractor. This is probably too much information but I have had a heck of a time locating a center wheel that is 28"has a 8 bolt pattern , 8" from bolt center to center with a 5 1/2" center hole. I can find a 6" center hole and it says it also fits a MF. The center hole might be 5 9/16" but it's certainly not 6. Will the 6" work since its bigger or will the extra space make it move. I mean it's going to be bolted to the loop rim and to the axle so will it work. Also the 8 holes look really big compared to the picture of the one I found that might work. I'm going to run it without fluid in the tires because all I do is Bush hog with it.
This post was edited by Tryinmybest on 03/26/2022 at 09:29 am.
