Geo-TH,In
Wore out mentioned plugged vent screens?
I Did a little searching and came across this.
I did have green/black rotor issues, moisture, gases, corrosion, all directly related to poor running and the P0300 because the distributor can't vent correctly.
I did notice green oxidation inside the cap.
When I replaced the cap/rotor, I used compressed air and blew out the screen.
Should I have done something else with the vent screen?
The pic above doesn't have a vent hole where mine does.
I solved the A/C issue. I covered the suction pipe with foam insulation. So water can't drip on the distributor cap.
The A/C hose above the cap deposits water on the cap as well on models with the hose routed over the cap.
How do I solve the venting issue??
My GMC is a 2007 4.3l 6 cylinder..
