(quoted from post at 09:55:25 03/22/22) Software in a tail light!!!!! ????????????
GMC is actively recalling the newly launched Hummer EV because of a possible tail light failure.
Software in the tail light assembly could prevent it from functioning as intended.
hich one?(quoted from post at 15:11:09 03/22/22) Who wants to work on this beauty?
n a vehicle, that electronics that never turns off will & has killed battery after it sits long enough. Only milliamps , but will kill it over time. Most drive more frequently than that, but say leave at hunting camp for months....better remove cable.(quoted from post at 15:46:50 03/22/22) Plus the device is always using power so in turn it make the electric bill higher
(quoted from post at 15:18:36 03/22/22) If people didn't buy them they wouldn't make them. It's that simple..
(quoted from post at 16:18:36 03/22/22) If people didn't buy them they wouldn't make them. It's that simple..
Personally, tech from about 1985 or maybe 68 was plenty good enough for me.
(quoted from post at 08:41:30 03/23/22)Personally, tech from about 1985 or maybe 68 was plenty good enough for me.
You can keep your 1985 or 1968 death traps!
(quoted from post at 09:41:30 03/23/22)Personally, tech from about 1985 or maybe 68 was plenty good enough for me.
(quoted from post at 07:17:34 03/23/22) But modern vehicles aren't lighter. Modern vehicles are far and away heavier than their antique counter parts. My 1950 Willys truck is 4x4 and has a GVW of 5300 lb. at a curb weight of 3300 lb. There isn't a modern light truck that has a curb weight of 3300 pounds, even a 2wd. My son's 1977 F250 4x4 has a GVW of 6600 lb, so that would mean the curb is about 4200 lb. There is no modern 1/2 ton 4x4 with a curb weight under 5000 lb., much less a 3/4.
(quoted from post at 10:09:14 03/22/22) General Mediocrity strikes again.
Or if searching for heavy and real heavy, try Rivian electric PU @7173# or EV Hummer @ 9046#(quoted from post at 11:39:49 03/24/22)(quoted from post at 07:17:34 03/23/22) But modern vehicles aren't lighter. Modern vehicles are far and away heavier than their antique counter parts. My 1950 Willys truck is 4x4 and has a GVW of 5300 lb. at a curb weight of 3300 lb. There isn't a modern light truck that has a curb weight of 3300 pounds, even a 2wd. My son's 1977 F250 4x4 has a GVW of 6600 lb, so that would mean the curb is about 4200 lb. There is no modern 1/2 ton 4x4 with a curb weight under 5000 lb., much less a 3/4.
Weight! Wait until all electric! 7,700 batteries make up 1700-1800 pounds of additional weight. Ford Lightening F-150 = 6500#, including batteries. Due to large usage of lightweight materials, it manages to hold it down to only 1685# heavier than the gas F-150 at 4815#. A mere 35% increase. :roll: Batteries weigh more than the 1/2 ton load capacity!!!
