(quoted from post at 12:26:13 03/13/22) Could be a safety, could be a linkage has come loose.
Just have to get into it, get it open somehow so you can find the problem.
(quoted from post at 17:04:07 03/13/22) My 2000 F350 same door gets stiff in cold weather also. Quick fix: install small electric heater in cab for a couple of hours & warm to approximately 75* & you're good to go.
(quoted from post at 07:07:26 03/14/22)(quoted from post at 17:04:07 03/13/22) My 2000 F350 same door gets stiff in cold weather also. Quick fix: install small electric heater in cab for a couple of hours & warm to approximately 75* & you're good to go.
Thanks, but this started over a month ago and weve had warm days and cold here. Its likely something is broken inside the door, have to get in there and see what it is. Hope yours holds up and doesnt go this way. Gerrit
