Stan Coryell
I have a tractor with an auxiliary hydraulic pump and spool valve (with pressure relief, power beyond, and open center) for the loader. I would like to run a 3pt log splitter off of this set up. I'm not sure how it gets hooked up.
If the log splitter is open center do I use the power beyond for the in on the log splitter and tee the out to the tank line?
Will this setup still use the loader spool as the relief?
The log splitter won't be plumed all the time. I plan to put quick disconnects in.
Thanks in advance,
Stan
Thanks in advance,
Stan
