Were attempting to add 1500# inside wheel weights to our JD 9400 tractor but having problems with getting the inside wheel off. outside dual came off without much effort but inside wheel wont budge. Anyone else try doing this? We didnt think that it was going to be such a tough job,were we wrong!Wheelis bolted to a cas hub, you have to remove the bolts and install bolts taken out in threaded cast hub thereby pushing it back away from the hub. We have so much pressure from the four bolts threaded into the hub, that I am afraid that anymore will break the hub cast! Has anyone attempted this? Any advice is greatly appreciated! Thanks so much!!
