(quoted from post at 21:18:54 02/25/22) Does anyone have info on a F20 by serial number?
Here's the link to what Tractor Data has: https://www.tractordata.com/farm-tractors/000/2/9/299-farmall-f-20.html
Hello L. Newsom welcome to YT! The page Doug is
directing you to is a little tricky to find if you are new
here especially if you are viewing from a phone. First
you need to be in Classic view, on a PC you will see it
on the left ..Serial Numbers.. On a phone you need to
select ..Options.. at the top first. Here it is in the link.
YT F20 serial number info
If using phone, click on (more) at the
top of page. Scroll down to and touch
serial numbers, then same for farmall,
then same for F-20. You'll find that
there is alot more on the site along
the way, versus just going straight to
the link/page, which you can also do.
Ah ha, I see the ..More.. at the top now and I see it is on Classic as well. I rarely post or view from Modern, I could get there as described in my other post so I am a bit like a cow, find my path an use it every time. Thanks!
FA 38662 Is the ser#.
I will be going to pick up the tractor this June.
Just wanted to know any info I can get on it. Thank you for your help
Thank you. Does it have any other info. The man holding it for me says it only has one fuel system on it. Thought it was rare/odd. Thank you very much.
(quoted from post at 12:36:19 03/01/22) Thank you. Does it have any other info. The man holding it for me says it only has one fuel system on it. Thought it was rare/odd. Thank you very much.
Single fuel system is not rare. Both my f12 and f14 were single.
