Barring a DT436
SouthNoack
New User
Is there a barring tool available for 300/400 series engine to roll the crank for valve adjustment? I've seen barring tools available for DD engines but I cannot seem to find anything available for the 300/400 series engines. I've got a 1486 with the DT436 which I would like to adjust the valves on while it's apart as far as it is.
Thanks,
Tim
Delta red can you open your e-mail have something to share with you or just send me and e mail
It depends on how far apart you have it . If not split from transmission to engine you take the
plate with tachometer transducer off and like said, just bar it over with screwdriver or bar in ring
gear.
If split, stick a bolt or bar into one of the frame rail bolt holes and pry off of that. Doesn't
sound like you have the engine out completely as that requires a little different method which there
are many.
No barring tool was ever released or needed on those engines.
E mail dpesmt seem to work om my phome
Home computer isn't yet hooked up.The I'M. on the phone has quit working too.But we can try email just on case.
Nothing real important just had something to share with you, hope you are in the new house and ready for warmer weather..
Thanks yall for your responses, much appreciated. Engine turns very (almost too) easily with a BFSD on the ring gear through the inspection hole. I thought it would roll a lot harder than it does. ;-)
My 1466 IH puller has a DT 466 thats been taken up to 570 cubes..Like mentioned its real easy to roll one over using a small pry bar on the ring gear teeth thru the timing
cover hole...I do this all the time when running the valves or timing the Bosch P-7000 injection pump...Its been decompressed and takes no effort at all.
If the fly wheel is on the engine and the starter teeth are exposed they make a tool for rolling over engines. It hooks on the stater teeth.
