I needed to make some repaires on my snowblower. Flat plate with short stub shaft was bent. Plate about 4 inches square and 1/4 inch thick. Shaft is welded into the center. Bearing for the upper auger rides on the shaft. The stub was bent on the plate pretty bad. Not sure how that happened. So I cut off the stub shaft the bearing goes on. Straightened the plate and was going to weld the stub shaft back on. No go. I keep my welding rods outside in an unheated garage. Most of my welding projects are during warmer dryer weather. Rods wouldnt burn and I got pretty frustrated. I guess Ill just put them down by the stove to dry out. Grrr !
