J Hamilton
- Location
- Southern Illinois
What would cause piston damage like this? Case VAC number 4 piston, camshaft side of piston. None of the others are damaged just normal wear. Conformatic GE 130 pistons. Sleeve just has light visible scuffing. No knocking or rattle from engine. Rod bearings are within spec when checked with plastigage, I'm going to check crank with micrometer. Wrist pin bushing DO have excessive wear. Would worn wrist pin bushings cause this damage?
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto114345.jpg>
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto114346.jpg>
This post was edited by J Hamilton on 01/16/2022 at 04:04 pm.
