Farmalllover13
Good evening. I recently purchased a 1948 Farmall Super A that needed 2 tires and a rim. he let me have 2 like new tires that I can put on when the bad ones get taken off. The rim is cracked and rusted so bad that it is undrivable. Both tubes were filled with fluid. All of the fluid has leaked out of the tire with the bad rim. If I replace that tire and rim is it ok if one of the tires has fluid and the other doesn't? Also, the tires on it now are 11.2x24 and the rims are 10". The tires he gave me are 9.5. I understand that 9.5 tires need a 8" rim. If I replace the original tire and rim that is cracked (11.2x24 with 10" rim) and put a 9.5 tire and 8" rim on it, is it bad to have a smaller rim and tire on one side? Thanks!!
