Or to put it another way how much back up do you have in your fleet? Finances are leaving me in a position where I can make some modest moves in terms of adding to my fleet. Can't do everything I want in one year but am zeroing in on my targeted acquisitions. I've already purchased a 14 ft field cultivator to have to be pulled by the 100 HP tractors here in case something happened to the JD 8430. Just curious as to what others are doing or have already done. Today the bottom line is you can't rent it or readily borrow what you need if something breaks down. I had an oil cooler seep on the combine this fall and had to buy another cooler from the parts yard as nobody does brazing or similar repair work anymore. That kind of repair is definitely not a strength of mine.
