Copperhead don't play
HELP please, had to take the four hoses off of the steering "device" that sends hydraulics to the power steering cylinder. Two of the hoses go the cylinder, one of the hoses is a low pressure return hose, and the last is a steel ridged pipe.
When I went to reconnect the hoses back, I could not remember which hole in the "device" each hose went. So, I guessed, and I guessed wrong. It took me and another mechanic 8 hours to replace the four hoses. The area is that tight and so hard to align the fitting and turning the wrench 1/6 at a time.
If you can take a picture of the hose placement on the "device" I will be so greatfull.
Thanks,
Copperhead
Thanks,
Copperhead
