Kioti hydraulic
Wanting to install a front loader on a LB1914 Kioti 4x4 with reverser/shuttle and power steering. Is there somewhere that I can tap into for hydraulic to operate the loader or do I need to add a separate pump? thank you, gregjo1948
No it will not. It comes with the valve but his tractor has a block in the hydraulic supply line
under the right floorboard. That is where you will get the power for your loader valve and plumb the
return. You need a manual .
