In Toronto, all cabs run on cng. Been that way for years. You can see Crown Vic's with half a million miles on them running like new.(quoted from post at 16:23:10 12/12/21) hey, lets switch to propane/ natural gas engines, less pollution. lol.
If you're saying that there haven't been any technological improvements in the last 50 years, I disagree.(quoted from post at 19:48:05 12/12/21) Less engine wear only applys to the bottom end running in oil. The valve guides on propane engines wear a lot faster due to the dryness of propane. So no use trying to say no. Seen quite a few when I was working in GM garage in the 70s. The stems would be just flopping around they were worn so bad on propane conversions. Gas engines were never worn like that. Same with those natural gas stationary engines on oil pumps. The valves done hold up. Same deal fuel is too dry to do any lubing.
Propane is used as an injectable enhancement on diesel engines in much the same way as nitrous oxide on a gas engine.(quoted from post at 22:42:30 12/12/21) I had a 76 Ford pickup with a propane carb. It would also run on gasoline. With the 360 engine with 8 to one compression, that got 12 MPG on gasoline, it only got 10 MPG on propane. With the 460 engine with 10.5 to one pistons, the mileage was the same with either gasoline or propane at 10 MPG. I couldn't tell much difference in power. Propane engines need at least 14 to one compression ratio. With a high compression ratio I believe the propane engine would put out more power than gasoline!
My neighbor was telling me that some guys were running diesel engines that ran on diesel and propane together. They supposedly were really putting out some power!
I now have that same carb on a little Subaru car!
(quoted from post at 19:50:12 12/12/21)Propane is used as an injectable enhancement on diesel engines in much the same way as nitrous oxide on a gas engine.(quoted from post at 22:42:30 12/12/21) I had a 76 Ford pickup with a propane carb. It would also run on gasoline. With the 360 engine with 8 to one compression, that got 12 MPG on gasoline, it only got 10 MPG on propane. With the 460 engine with 10.5 to one pistons, the mileage was the same with either gasoline or propane at 10 MPG. I couldn't tell much difference in power. Propane engines need at least 14 to one compression ratio. With a high compression ratio I believe the propane engine would put out more power than gasoline!
I am very sorry that my post upset your sensibilities. I simply meant that the diesel guys use propane to get "a little more", and the gas guys use nitrous to get "a little more". Of course, the nitrous guys have to add additional fuel to keep from melting pistons, but my point was the "a little more" factor. Again, please accept my humble apology.(quoted from post at 11:43:29 12/13/21)(quoted from post at 19:50:12 12/12/21)Propane is used as an injectable enhancement on diesel engines in much the same way as nitrous oxide on a gas engine.(quoted from post at 22:42:30 12/12/21) I had a 76 Ford pickup with a propane carb. It would also run on gasoline. With the 360 engine with 8 to one compression, that got 12 MPG on gasoline, it only got 10 MPG on propane. With the 460 engine with 10.5 to one pistons, the mileage was the same with either gasoline or propane at 10 MPG. I couldn't tell much difference in power. Propane engines need at least 14 to one compression ratio. With a high compression ratio I believe the propane engine would put out more power than gasoline!
Please go ahead and explain how nitrous alone adds power to a gasoline engine .
Adding LP to a diesel only works if there is enough unused O2 to allow complete combustion .
LP does not have a high enough octane to be operated in a Diesel engine with pilot injection at full power .
As soon as the amount of LP injected into the intake rises above the LEL . The engine will suffer from detonation .
A diesel will operate just fine on NG at
Full power when using a pilot ignition system . NG octane rating is much higher than LP .
(quoted from post at 05:43:29 12/13/21)itrous alone[/b:f8da0de2dd] adds power to a gasoline engine .(quoted from post at 19:50:12 12/12/21)Propane is used as an injectable enhancement on diesel engines in much the same way as [b:f8da0de2dd]nitrous oxide[/b:f8da0de2dd] on a gas engine.(quoted from post at 22:42:30 12/12/21) I had a 76 Ford pickup with a propane carb. It would also run on gasoline. With the 360 engine with 8 to one compression, that got 12 MPG on gasoline, it only got 10 MPG on propane. With the 460 engine with 10.5 to one pistons, the mileage was the same with either gasoline or propane at 10 MPG. I couldn't tell much difference in power. Propane engines need at least 14 to one compression ratio. With a high compression ratio I believe the propane engine would put out more power than gasoline!
Adding LP to a diesel only works if there is enough[b:f8da0de2dd] unused O2 to allow complete combustion . [/b:f8da0de2dd]
(quoted from post at 13:19:46 12/13/21)(quoted from post at 05:43:29 12/13/21)(quoted from post at 19:50:12 12/12/21)Propane is used as an injectable enhancement on diesel engines in much the same way as [b:8e20e6b243]nitrous oxide[/b:8e20e6b243] on a gas engine.(quoted from post at 22:42:30 12/12/21) I had a 76 Ford pickup with a propane carb. It would also run on gasoline. With the 360 engine with 8 to one compression, that got 12 MPG on gasoline, it only got 10 MPG on propane. With the 460 engine with 10.5 to one pistons, the mileage was the same with either gasoline or propane at 10 MPG. I couldn't tell much difference in power. Propane engines need at least 14 to one compression ratio. With a high compression ratio I believe the propane engine would put out more power than gasoline!
Please go ahead and explain how [b:8e20e6b243]nitrous alone[/b:8e20e6b243] adds power to a gasoline engine .
Adding LP to a diesel only works if there is enough[b:8e20e6b243] unused O2 to allow complete combustion . [/b:8e20e6b243]
Well, first off - he said "nitrous oxide", and you re-named it as "nitrous"(I don't know what that is, but maybe you can explain what "nitrous" is to us).
Second, Nitrous Oxide (N2O) is a very strong oxidizer. Which means, it produces a lot of free O2 for added combustion of most carbon and hydrocarbon based fuels.
Third, when N2O is injected into any internal combustion engine, it is almost always combined with an added fuel injector to make up the correct stoichiometric ratio to burn inside the cyl.
I agree "nitrous" alone(whatever that is after you tell us) won't do anything without concomitant added fuel. Doesn't matter to me if one adds LP, gasoline, butane, diesel, kerosene, etc. BTW, N2O has been used in rocketry to increase the O2 content of the engine during the later phase of the burn where the inert N2 is a cooling agent for the manifold rings which tend to get darn hot and burn off.
This post was edited by docmirror on 12/13/2021 at 09:20 am.
(quoted from post at 10:57:42 12/13/21)(quoted from post at 13:19:46 12/13/21)(quoted from post at 05:43:29 12/13/21)(quoted from post at 19:50:12 12/12/21)Propane is used as an injectable enhancement on diesel engines in much the same way as [b:5dce760d9a]nitrous oxide[/b:5dce760d9a] on a gas engine.(quoted from post at 22:42:30 12/12/21) I had a 76 Ford pickup with a propane carb. It would also run on gasoline. With the 360 engine with 8 to one compression, that got 12 MPG on gasoline, it only got 10 MPG on propane. With the 460 engine with 10.5 to one pistons, the mileage was the same with either gasoline or propane at 10 MPG. I couldn't tell much difference in power. Propane engines need at least 14 to one compression ratio. With a high compression ratio I believe the propane engine would put out more power than gasoline!
Please go ahead and explain how [b:5dce760d9a]nitrous alone[/b:5dce760d9a] adds power to a gasoline engine .
Adding LP to a diesel only works if there is enough[b:5dce760d9a] unused O2 to allow complete combustion . [/b:5dce760d9a]
