jimg.allentown
I have a very old walk-behind tractor. This would be VERY handy for my little garden. I also have several
attachments for it including a single bottom Brinley plow with coulter.
Problem is that the engine on it is just plain old and worn out. Carb leaks even after cleaning and replacing
gaskets. Fuel tank sediment bowl will not seal right. It also smokes quite a bit when it is running.
I want to replace the engine, but I keep running into problems. The original engine (as far as I can tell) is
about 3 to5 hp. It has a 1 inch horizontal output shaft. Replacements I find in that horsepower range all have
smaller shafts or have to be mounted too far forward to clear the gearbox. I have a 6.5 hp Briggs engine that I
had as a spare for my tiller, but it simply has everything in the wrong place (most I can deal with) and the
output shaft is only 3/4 inch.
Every replacement I have looked at is either prohibitively expensive or has a smaller shaft. Looking for
suggestions on what might replace it. BTW, already looked at the HF 6.5 hp engine. That would be nice, but it
only has a 3/4 output shaft. Next step up costs too much more.
