I've had no problems buying parts for all my old stuff. Just got a new master brake cylinder for the 64 Chevy this summer through Rock Auto.(quoted from post at 20:15:09 11/10/21) I tried them,NAPA, Had a '79 Chevy C60 that needed a brake drum but it's obsolete now also. Everyone is telling me they're parts system stops at 1980 now.
I restore and work on old IHC trucks. restored 2 1974- 200 trucks from the ground up parts you either have to buy used stuff and redo it or make it yourself. I got4 of the 1974 200 trucks all 4-WD 2 with 4-speeds and 2 automatics.(quoted from post at 12:00:54 11/11/21)
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto107694.jpg>
(quoted from post at 13:35:28 11/11/21)I restore and work on old IHC trucks. restored 2 1974- 200 trucks from the ground up parts you either have to buy used stuff and redo it or make it yourself. I got4 of the 1974 200 trucks all 4-WD 2 with 4-speeds and 2 automatics.(quoted from post at 12:00:54 11/11/21)
Earlier this year I bought a 1976 Scout traveler. This is the longer one it had been wrecked in it life and rather than fix it right they body filled it in to the point it was falling off. Called a place in Ohio to check on quarters got lucky they had a set of NOS setting there.
The place in Ohio acquired some of the tooling from IHC when they went under they can make the orginal floor sheets for the PU'S.
The stuff is out there just have to keep looking for it.
