(quoted from post at 23:08:02 11/09/21) Your suction side hose is a mess. You need to get the kinks out and maybe get a larger one.
hen you get the rest of it fixed up, get yourself a detent valve and you won't have to stand there holding the handle while it returns.(quoted from post at 21:43:56 11/09/21) Took a long time to load on YouTube.....
Slow log splitter
(quoted from post at 11:01:52 11/10/21)
From your description, [b:432a5260f6]I would guess your pump was not designed to run from a PTO as the one on his splitter is[/b:432a5260f6]. One would need to be careful about using a speed step up like yours on the type pump designed to run at PTO speed.
(quoted from post at 11:42:44 11/10/21)(quoted from post at 11:01:52 11/10/21)
From your description, [b:660a49ca6c]I would guess your pump was not designed to run from a PTO as the one on his splitter is[/b:660a49ca6c]. One would need to be careful about using a speed step up like yours on the type pump designed to run at PTO speed.
You would be right. It is the type that would be driven by a small engine or off the front of the tractor's crankshaft pulley.
Regardless, it keeps the tractor's RPMs, noise and possibly wear and tear down which is my reason for describing it.
Should have been clearer about that I guess.
Back to his. If the pump wasn't getting enough fluid to operate the cylinder fast, would the cylinder's action not be jerky or jumpy for lack of better terms?
(quoted from post at 18:47:58 11/10/21) Log splitters usually run ar 36 hundred RPM
