PTO generator
johnofnewhaven
Got the old PTO generator out and have the house running on it now. Just testing it out. I try to do this 4 times a year to make sure it operates good. The generator is a 1967 and the 3000 is a 1970. If my power does go out I run the generator off my Ford 5000 diesel. I know a whole house automatic generator is the way to go but I rarely lose power. Yes the house is properly wired for the generator.
It looks like a Dayton. A friend has one which has us stumped. It will operate 120V off of either line. Voltmeter shows 240V. Yet hook up a 240V load, and nothing happens!
Excellent practice to test
Run every four months .
At max output the generator will require 23 PtO HP . The
3000 has plenty of snort to operate the generator .
Interesting. It looks just like my friends Dayton. It looks nothing like my old Winpower. Someone must be making something for someone else.
I have started a hard starting 10 HP centrifugal fan with my 25/15. I need 50 to 60 HP in front of it to do it. It groans to do it, but the trailer doesn't offer to move.
I've seen many sell - usually in the $1000 to $2000 range.
Month ago I was at a well attending auction where the owner (who had well kept equipment assured the crowd the Winco 33K PTO generator worked fine. I brought it hone for $240. Brought it home and it worked fine.
The two 120V output windings might be wired back-to-back, instead of in series. So, you will get 120 on each of the two legs, but won't produce any power on 240, even though you can measure 240. Any numbers on the load wires coming from the generator end ? I.e, T1, T2, etc? zuhnc
