Return oil port location, Oliver 1600
So I have a 1600 U with a loader on it. I have the loader hooked to the two remotes. Then I drilled some holes in the bottom of the bucket to put a bracket for a hydraulic post hole auger. I have a valve mounted under the right floor plate that has a solenoid on it to divert the bucket oil to the auger motor. I just need to plumb a line from that valve back to the hydraulic reservoir. Is there a plug on the right side of hydraulic housing that is open for return oil?
Go to YouTube and search That Oliver Guy. He's done several videos on power beyond on different series Olivers.
Be advised what we have ran into several times in trying to do it like you are is that by the time you go thru your loader valve and then the diverter valve you may not have enough FLOW to run your hydraulic augur . Lot depends on what brand and flow requirements.
