Head bolt thread sealant question
montidale
I am about to assembly head on a 8N Ford. The head bolts go into the water jacket, so I am thinking about putting some thread sealant on the bolts. I have been using a pipe sealant with Teflon made by loctite. I cant seem to find that in the parts stores anymore. What does everybody else use to seal their head bolts so coolant doesnt leak?
(quoted from post at 08:59:32 10/28/21) I am about to assembly head on a 8N Ford. The head bolts go into the water jacket, so I am thinking about putting some thread sealant on the bolts. I have been using a pipe sealant with Teflon made by loctite. I cant seem to find that in the parts stores anymore. What does everybody else use to seal their head bolts so coolant doesnt leak?
ndian Head shellac compound.
I have used many different types over the years, and have had trouble a few times. Now I only use ARP part #100-9904 and never had any trouble since.
I'd mix up some J.B. weld and coat the
bolt threads. Screw them in before it
sets up. I hope you don't want to take
them back out. LOL.
No, that was just a joke. Don't do
that.
I'd be more worried about the bolt
rusting solid to the block over time.
If it were me, and the head gasket had
the same ring around the bolt holes as
it does for the water ports, I would
use some kind of anti-seize paste.
You'll be able to get bolt out much
easier next time. No need for sealer
IF gasket has the anti-leak ring
around the head bolt holes. If water
comes up through the threads with
anti-seize paste, it'll be stopped at
the non-leak ring in the gasket. The
paste will virtually stay put. Still
be there years later for future bolt
removal.
Permatex non hardening works good. I am sorry this will make someone mad,never use silicon in threads. I have seen castings split from the force of studs going in blind holes with silicon used.
(quoted from post at 08:02:53 10/29/21) Well, looks like theres lots of options here. I think Im leaning towards a Loctite thread sealer.
ometimes getting many answers is worse than getting none. But, Indian Head Shellac Compound, seriously, that's what it's for.
I have had failures using RTV silicone on threads into cast iron where water is involved. The water will follow the threads in the cast iron slowly eating its way in until there is not enough thread left to hold. The silicone won't seal to rust.
