1949 Case DC
JDeming
New User
I have a 49 Case DC with an F-10 on it. Been sitting in the junk row and last time it ran was 15 years ago. I don't know to much about the setup. I assume it can lift a round bale (up to 1600#) without problems. I can't find any information on lifting capacity. Debating on restoring to usable conditions but want to make sure of capacity first. Any info would be appreciated.
Bridge style? It'll lift a lot higher than
a non bridge style, but both will probably
lift a 1600# bale as high as you want it,
unless you are trying to put them in the
upper story of the barn. After running a
bridge style for many hours, I'd think the
DC's hand clutch would be a significant
handicap in the operation of an F-10.
how high are u needed to lift them? off the ground to move or high enough to dump in a feeder? and yes you can roll feeder on after but in
winter when froze down thats kinda out.
i just used my w6 with farmhand to level some dirt few days ago works good for that. i have an F10 on a farmall H also looking at those cyl's i might lift a bale but be pretty tippy once its on, as the tractors are pretty rocky once they have weight on the front. then u need some way to keep the bale on the front like longer forks. i just dont think it would be practical as an everyday user thing for bales.
then to steer the tractor is another thing too.
(quoted from post at 10:50:27 10/24/21)
Those DC4s were heavy steering with just their own cast wheels on the front. I can't imagine trying to drive one with a loader and a 1500 pound bale hanging on it. Plus my DC4 has been a "pull start" tractor for years although everybody tells me they are a good starter.
Lack of frame rails along the engine is a big hindrance to a loader on a DC. relying on the engine block for stregnth
