Dear barney
SVcummins
Dot makes the BEST homestyle pretzels.
Tell Barney.
He could hand out a bag of pretzels instead of a ticket.
If anybody has pulled one of those trailers built like those the tongue weight is not the problem power and weight to pull it well is the problem. They are fairly well balanced like that. The old A-frame trailers had the tongue weight on them loaded like a lowboy trailer with the wheels at the back. I liked the A-frames better than those drive one with those little tires though. Guy I worked for on a wheat crew the one half of the crew was always changing tires on those little tires. The A-frames were not much of a problem with tires unless they were run low on air. He had 10.11-20's tandem axles with duals on them still would out last those 10.00-15s or 17.5s. Changing was an act of work without unloading the combine.
If that one has you having an apoplexy, you should see the rigs they use to transport self-propelled swathers around out in grain country.
...and I think the trailer is FACTORY built.
This post was edited by BarnyardEngineering on 10/22/2021 at 04:32 am.
Those are factory built , thats also a swather not a 2188
combine . I think thats a pretty smart swather trailer actually
I like the original flavor the Best try em with your favorite cheese sliced . I havent been able to find em for awhile
