Kubota 3 pt
bfullmer
Have older Kubota BX 2230 is there an adjustment on how high 3 pt goes up ? It seems to go too high and pto shaft binds ?
The adjustment is in your right hand , just do not pull the lift lever back all the way , only move it up just as high as you need.
The control lever is connected to a rod that activates the control valve. There is an adjustable stop on the rod that pushes the handle back to neutral. You can change the lift height by moving the adjuster.
Mark
Mark do you have a bx to ;look at, I was going to tell him to adjust the rod. I know al the B series do have the adjustment but looking in parts I cannon find the adjustment lever on the early BX , I hope you are right but just could not find one.
I don.t have one but I work at a Kubota dealership. The adjuster is item 60 in the image for the hydraulic control lever. i can't post a link direct to the image but it can be found from this link.
Mark
Kubota parts
