Can someone explain to me in laymans terms the difference
between a 12v coil no external resistor required that is rated
at 3 ohms vs one rated at 1.5 ohms. Yes I understand 1.5 is
half of 3. Im not sure what it means when one or the other is
on a tractor. Ive been fighting with our 1650 Oliver. Has
electronic ignition. I have the correct wires, and want to make
sure I have the correct coil. Petronix says to use a coil rated
at 3 ohm for 6 cylinder applications unless its a racing
application which the you would use a 1.5 ohm coil. Ive been
fighting this tractor and have several posts on the Oliver
board. Im posting this here because of a little more traffic.
Currently it has a 12v coil on it from Napa which says no
external resistor required. Not sure of the ohm rating of it.
