Your question always generates the same first response which is another question. DO YOU HAVE THE MANUAL? Many cabs don't need to be removed to change the clutch.
No i dont not have the manual i have done cab removal in past for clutch replacement this is the first kubota cab.I seen a older post from jm that there were tips and tricks
(quoted from post at 04:56:30 10/13/21) The post was to old to reply to
That's fine. You should not reply to old posts anyway as it just causes confusion. People will reply to the first post in the thread, and ignore yours.
In the future, use the subject to give a synopsis of your question. "M9000?" M9000 what? That's what I was thinking when I saw the thread. Opening the thread didn't help, as I had no idea what you were asking about.
Something like "Kubota M9000 clutch replacement" for your subject would have made things so much clearer.
Please take this as constructive criticism, not a personal jab.
Like ever one says you need the book but here are a few quick tips and things to watch. The most common mistake is when you go back installing the mount washers wrong. The big bolts and mounts there at the front corner of the cab have to be installed right or you have problems. Pay attention to how the washers and spacer go. Have had folks ruin the tack cable , you have to go behind the dash and remove all wiring and tach cable. You leave the rear cab mounts and let the cab stay on the back as you roll it away front the front half. You need a splitting stand to be safe but i have seen folks use a floor jack. Block the front and also wedge something in between the frame and front axel where it will not move.
Yes it is!I have done several deere and newholland just not a kubota if figured by some of the inspection plates you could acsess some of the bolts.
Go to a site called manualslib put in your tractor model. And it looks like you can view the manual online for free. You can download it from there but I have never tried it. The site gets okay reviews. I have only viewed it on an iPhone and their browsers are pretty good at suppressing pop up adds so I do not know how it will look on a PC. I can tell their are a lot of adds. A lot of other free manual sites are known to have ..spam or virus links.. so just use caution.
