John Deere 825 rollover plow vanes
craigco
Think I found the reason the plow won't
roll over. One vane has a crack running
down edge. Vanes are hard to come by and
around $400. Does any one know where I
might find some good used ones part number
a10881a? Thanks
It might be worth investigating if that vane wasn't also used somewhere else... like a 2 cylinder power steering or a backhoe center cylinder. I'm guessing Deere borrowed some engineering from somewhere else for the plow.
Would a vane - F1697R-from a two-cylinder tractors power steering work?? JD part number is
different - plow no vane is A10881A-- but the packing number -F1697R- is the same..
Photos won't load but where the vane tapers down on the end one has a crack from top to bottom about the thickness of the rubber seal. If I pull it out to put a new seal in it will not hold a seal any more. I will look into the 2 cylinder vanes also.
