Bob N.Y.
- Location
- Norway, N.Y.
I am resurrecting a 1930 Model A Ford doodlebug. It was already converted to 12 volts negative ground and I am keeping it that way. It still has the original starter and the positive cable goes directly from the battery to the starter, no solenoid. I have read comments on here about using larger cables for 6 volt systems and smaller cables when 12 volts are being fed to a 6 volt starter. What size cables should I use in this application? The positive cable needs to be 30 inches long and the negative cable needs to be 12 to 14 inches. Thank you.
