Woodland Clan
New User
My Case 580B was working great. I had actually just changed out the transmission fluid the day this happened and the drain plug had been off for days. Working the machine, suddenly fluid started pouring from the top of the tube under the block. Still moving fine but leaking a lot of fluid. I parked it, shut it off, and it came out even harder. I started the machine back up, you could hear pressure building from what I can only describe that looks like a port or weep hole under the block. It started coming out again, from the "port" or "wheep hole" that I just mentioned. I shut the machine off and again it surged out. I believe it drained all my fluid because the machine would no longer go forward or back. I haven't checked the level, I called it a day and went home.
I'm not sure as to why it was so creamy, since I had literally just put new fluid in the morning and it was working fine. But would this happen if there was too much water in the system? Would a pressure or "dump" valve be stuck and pouring it out?
Any help or insight would be great! As of now I plan on pulling the fuel tank off Monday morning and then removing the block to see if there's any blocked passages? If anyone has some insight before I do that and ruin the gaskets that would be great!
Thanks!
Here is a link to a video I posted of it on youtube looking for help
https://youtu.be/KaF9iuWENmE
This post was edited by Woodland Clan on 09/25/2021 at 10:54 pm.
Thanks!
