Just got home from large estate auction. The deceased owner went to a lot of auctions and bought whatever went cheap. All these
were parked outside. The sheds are full with better stuff that will sell around Halloween. DNR = does not run
White 6 btm onland hitch plow $950
White 4 btm 548 plow $700
JD 7720 combine runs but dash is dead with 6 rn corn head $2300
JD 6620 titan 2 4wd 215 grain head runs $5250
Oliver 548 6 btm plow $650
M-F 620 20' disk with all new blades (about $3000 worth) $1500
White 2-105 2wd broken cab window runs $5700
Oliver 1850D 2wd good tires $4700
Oliver 1850d 2wd good tires $5000
Oliver 1850D 4wd $13500
Ford 8530 4wd $16500
JD 8440 $9200
IH 4166 DNR $4300
Oliver 1800C D with several front weights
IH 656 G $1700
Oliver 1650 D front weights good tires $2700
Oliver 1650 G good tires $6700
Oliver 77 G $2850
Farmall H $1000
Case 930 D DNR $850
MM Jetstar $900
Oliver 770 G Wheatland front new tires $2600
Oliver 1900A D DNR $3800
Oliver 1800A G runs $1300
Oliver 880 LP DNR $1050
Oliver super 88 D runs $3250
Oliver 88 D DNR $1300
Mc-D W-9 DNR $800
A lot of the tractors went to the scrappers for $300-500
JD 8440 $9200
IH 4166 DNR $4300
IH 656 G $1700
Oliver 77 G $2850
Farmall H $1000
Case 930 D DNR $850
MM Jetstar $900
Mc-D W-9 DNR $800
