3 point hookup carryall question
KD Cannon
Looking to purchase 3 point hookup carryall forks for my JD 1010. Something I could slide a pallet onto forks to carry feed, small square hay bales, few cinder blocks ect. Any recommendations for brand quality or features to look for & farm stores that carry them?
Would like to try to keep purchase around $200. I'm in Ks, 60 miles or so south of Kansas City. Thank you.
Cannon
King Cutter and others have light duty attachments for 250 or less, But Real forks that would serve will be more like 700 dollars.
less robust attach points and frame structure will bend and fail easily. Rated loads are likely to be centered an operated on
pavement to prevent bouncing. Something like model 2000, or 3542 from Northstar Attachments. Jim
I got one of these. Works well for me and what my tractor can lift.
No point getting something that is rated for more than your tractor can carry.
I just got a plastic pallet and added onto it to carry tools and such.
Part of it has a cabinet with work surface. Place for various tools and small genny for ac voltage tools.
3 point forks
Im in Cleveland, MO. Ill sell you a home made carry all.
Guaranteed not to bend or break. Forks on the bottom are not
parallel and will not slip into a pallet. Needs a new wood deck.
$250
James
9136457775
Really like the one from Agri-Supply. Imagine shipping to Kansas would be pretty expensive though. I'll try to find something like it closer to home and go pick it up myself. Thank you all for your help and comments.
Cannon
If the link does not work it is South of KC, west of Harrisonville just inside the state line. It seems due to their location they may know each other and Gwiz is maybe poking his buttons.
To KD if you go through the online shopping check out as if you were purchasing the unit it will tell you exactly what the shipping will be.
Cleveland, MO
(quoted from post at 14:31:39 09/25/21)
Cannon
When I got the agri supply forks four years ago it was $100 cheaper so it is now a third more.
Shipping via truck freight was pretty good, but only half as far as for you.
Freight was almost half of to the house because I had them ship and hold at freight terminal for me to pick up.I
You might google who has terminals near you before calling Agri Supply for shipping quote.
They used AAA Cooper for me.
This post was edited by DoubleO7 on 09/25/2021 at 12:26 pm.
I've got a bale carrier that a pallet will slide right on. It would work perfect for what you are doing. $200 I'm north of you by Council Bluffs Iowa. 402 681 9551 Gerald
