Looking for repair service for JD - B
chas036
I have a late model B that I need the clutch pulley repaired. The hole in the operating sleeve that fits over the drive pin is wallowed out to the point I can't adjust the clutch any more. I need someone who can remove that operating sleeve and weld the hole back into spec to fit the drive pin without and side to side play. I live in upstate NY, so anyone within 100 miles of Binghamton would be great. Also if you know of a salvage yard that has late model B's , that info would help also since I would consider buying the whole clutch pulley assembly if it had a good operating sleeve.
Two places down in Penn Yan , N Y would be north/west of Binghamton .
First try: A@L Parts 432 N Flats RD (315)- 536 - 0543
Second try :Nelsons 1387 Co Rte 23 1 (800) - 730 - 4020
A@L advertises 2 cylinder parts , Nelsons deals in newer JD , but may have some older, been a long time since I've been over in that area , call each ..
