Kubota L3010 with LA481 loader.
Dave BN
Anyone else have this combo? It works great but I struggle to get the loader on and off. There are pins at the rear to hold the loader arms and pins in front ahead of the the front wheels. I can never get it lined up correctly to get all 4 pins in or out. Takes me about an hour and full use of my vocabulary to get on or off. Finally I have to pry it into place with heavy bars.
What am I doing wrong?
I follow the books directions and am on a smooth cement floor.
Dave
I can't help you. I'm not brave enough to remove my loader. I just remove bucket to lighten front end when mowing. When I get the urge to remove mine, I sit down and wait for the urge to go away.
Open your e mail or send me a phone number and I will talk you thru it and give you 28 years worth of experience. Should not take over 15 minutes at the most to pull the loader.
My Kubota is just two pins; one each side in the towers. Does your loader have the built in support legs under the front part of the main loader arms?
I have a L3430 tractor and I think LA772 loader. I raise the loader until I can drop and secure the support arms. Then I rest he bucket on level ground and pull the two tower pins. By using the BUCKET control I can lift the arms out of the tower. I then back up a few inches, turn off the tractor and disconnect the hoses. Takes me about 10 minutes off and ten minutes on.
I have a L4310 i always read the directions when im taking it on or off seems to help.i put a quick attach on my loader arms awhile ba back now i just remove the bucket to lighten up the weight on the front
I have that same combination though my looks a lot more worn, LOL. The dismount/ mount is not easy. I follow the instructions each time because a mis-step will make it much tougher. The most important thing is to have it on smooth level pavement or concrete. I use a two foot level to verify that the loader and the rear axle are level before removal. Since I started doing this it has gone much better.
His 10 series is before the 30 series has 4 pins and is a little more complicated than the 30 series loader.
