1973 Massey Ferguson tractor diesel
koenton
Hello To all
Looking for a wiring diagram for a 2 wire from ignition switch, white and brown is what on switch, would any one
Have a diagram or picture? Thanks for any info
(quoted from post at 21:54:53 09/20/21) Hello To all
It helps if you tell what you are working on to save folks having to go to your old posts to try to figure it out. I am guessing you are working on the 135 diesel you previously posted about. The operator's manual I previously posted a link to for you had a wiring diagram for a diesel. The one in that diagram is a two wire start switch, it only operates the starter. If you have an on/off ignition switch it would go ahead of the start switch or start button. It would have a power wire from the ammeter and the second wire would go to the starter switch to give it power.
Jim.me
Did not get the sight to open and now it want go to sight could you sent me the wiring info for the 2 wire ignition switch again?
Sorry I forgot to put the 135 mf on it form Tanks for the com back to me, will try to post better next time.
Will in Al
Wiring diagram for a two wire from switch with gauges and alternator
and battery Thanks for any info.
1973 135 Massey Ferguson Tractor
(quoted from post at 10:29:44 10/05/21)
The wiring diagram shows a light green wire between the start switch and ammeter (which would power the switch) and a tan wire going to the starter solenoid. The gauges are turned on and off by an oil pressure switch mounted behind the oil pressure gauge. The diesel did not have an ignition switch.
This post was edited by Jim.ME on 10/05/2021 at 03:41 pm.
