youngohiofarmer
New User
Working on a new to me 1855 Oliver tractor. When I am trying to connect the hydraulic hoses to the remote (only has one) I can not get the hoses plugged into one side of the outlet. I can plug in to the other side no problem tractor running or not, but I can not plug into the other side. Even after I shut the tractor off and move the hydraulic lever, I still can not get the pressure to release. I end up having to crack the line to bleed the pressure. Once I get the hose hooked up the remote seems to work fine, always lifts and lowers the implement. I have tried multiple implements and even just my jumper hose. Any help is appreciated.
Thank you
Thank you
