Company Logo (800) 853-2651 Shop Now
Tractor Talk Discussion Forum
Barr's hydraulic system stop leak
andy r
09-14-2021 17:58:51
Does this product work? I assume is softens O - rings and other rubber components making them expand and seal better. Bottle says it might have some fibers in it as well. Could there be any downside to the product like causing the seals and O - rings to eventually breakdown? Anyone have any experience with the product? Thanks.
MarsEnthusiast
09-14-2021 23:47:41
 Re: Barr's hydraulic system stop leak in reply to andy r, 09-14-2021 17:58:51
https://atpautomotive.com/fluids-and-additives/re-seal
I had good luck with this, albeit not in a hydraulic use but in a crankcase
Actually, I lied, I forgot I used some in my plow hydraulics on my truck and it definitely halved the up-cylinder which had a weep that was getting worse. it just now is always has a little wet but its not dripping on the ground. but the fluid was in need of change and was also changed for fresh fluid, so that prob helped too
SVcummins
09-14-2021 21:32:52
If it has fibers I wouldnt use it
lugnuts2030
09-14-2021 18:30:08
I am a farmer and I have used seal-lube by New Tech avail online for 20 years and its works to soften seals in older equipment in the engines and trans hydraulics. My first experience was with a 20 year old tractor where the front engine seal was leaking. I put in about 1/4 the recomended rate ONE time 20 years ago and to this day the seal has not leaked saving many $ and time. I used it in tractors even with wet brakes and have had 0 problems. It will not repair a torn seal, just softens the old seals that have gone flat. I think this is the top of the line brand.
optiman
09-14-2021 18:15:02
In my opinion if you have a leak than fix it proper and don t go the easy route
J Hamilton
09-14-2021 18:13:02
Personally, I wouldn't put anything besides the correct fluid in any hydraulic system. Especially something that says may contain fibers. Just my opinion.
Today's Featured Article - The Mud Daubers and the Old John Deere - by Jon Zehnder. I have a 1941, John Deere Model A tractor I have owned for about a year and a half. This is my first (in case my wife reads this, "FIRST") tractor and it has been a learning experience. After considerable advise and assistance from local tractor nuts and the forums of Yesterday’s Tractors, I had finally got it running pretty well. I have tuned it up, overhauled the carburetor, installed a borrowed, rebuilt magneto, installed a new Power-Trol, patched the radiator, installed new front wheels a ... [Read Article]
Latest Ad: 2-11x38 nine hole tractor rims. Fair condition, 100 each. Phone calls only, no texts or emails. Winfield, KS 620-222-1314 [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
